Tech
January 9, 2023
No-code Databases 101
Introduction to relational databases with no-code
Founder and CEO of Noloco
Summarize with AI
If you are familiar with spreadsheet software like Microsoft Excel or Google Sheets, you are already well-equipped to learn about relational databases. A relational database is similar to a spreadsheet in that it stores and organizes data in a structured way, using rows and columns. However, there are several key differences between a spreadsheet and a relational database that make the latter a more powerful tool for storing and managing data.
One of the main differences between a spreadsheet and a relational database is that a spreadsheet is a flat file, meaning that all of the data is stored in a single sheet. A relational database, on the other hand, is composed of multiple tables that are connected through relationships. This allows you to create more complex relationships between different pieces of data, making it easier to search, sort, and update your data.
Another difference between a spreadsheet and a relational database is that a spreadsheet is designed for manual data entry and manipulation, while a relational database is designed for efficient data processing and querying. A spreadsheet is typically used to enter data manually and perform simple calculations, while a relational database allows you to create complex queries to extract specific information from your data.
Despite these differences, a spreadsheet and a relational database share many similarities. Both use rows and columns to organize data, and both allow you to sort and filter your data. If you are familiar with spreadsheet software, you will find it relatively easy to learn about relational databases and how to use them for your business or organization.
In the following posts, you will learn more about the components of a relational database, such as tables, fields, and primary keys, and how to create and design a database using a no-code tool like Noloco or Airtable. You will also learn how to query and filter your data using Structured Query Language (SQL) and how to import and export data from your database. Finally, you will learn about advanced database concepts and how to use relationships to connect different tables and create links between different pieces of data.
Your business needs an operating system, not another tool.
Bring your operations, work and reporting into one system built around how your business actually works. Give your team clarity, automate repetitive work, provide clients with a professional portal, and track profitability in real-time—all without replacing tools you already rely on.
Join 1,000+ businesses using Noloco to improve margins and scale their operations with the speed and flexibility of AI and the reliability of a no-code business software.
Get Started for Free
Author
Our recent posts
Explore all blog posts
Your most common
questions—answered!
Who is Noloco best suited to?
Noloco is perfect for small to medium-sized service businesses like consultancies, agencies, advisory firms, as well as  engineering and industrial services such as energy, construction, or any other operations-focused fields.
Not at all! Noloco is designed especially for non-tech teams. Simply build your custom system using a drag-and-drop interface. No developers needed!
Is my data secure?
Absolutely! Security is very important to us. Our access control features let you limit who can see certain data, so only the right people can access sensitive information
My business is growing fast—can Noloco keep up?
Can I make changes to my app after it’s been created?
Of course! You can adjust your app whenever needed. Add new features, redesign the layout, or make any other changes you need—you’re in full control.
Ready to boost
your business?
Build your custom tool with Noloco
