No-code Databases 101
Using relationships to connect data
Gill O'Leary
Summarize with AI
In a relational database, relationships are used to connect different tables and establish links between different pieces of data. There are three types of relationships that can exist between tables: one-to-one, one-to-many, and many-to-many.
One-to-one relationships:
A one-to-one relationship occurs when one record in a table is related to only one record in another table. For example, you might have a table of employees and a table of login information, where each employee has a unique login. In this case, the employee and login tables would have a one-to-one relationship.
To create a one-to-one relationship between tables, you would typically use a foreign key. A foreign key is a field in one table that contains the primary key of another table. The primary key is a unique identifier for each record in a table. For example, you might have a primary key field called "ID" in your employee table and a foreign key field called "employee_id" in your login table. This would allow you to link each login to a specific employee.
Here's an example of a one-to-one relationship between the employee and login tables:
Employee table:
Customer ID Customer Name Contact Information
1 John Smith john@example.com
2 Jane Doe jane@example.com
Login table:
ID Employee_ID Username Password
1 1 jsmith abc123
2 2 jdoe def456
3 3 bjohnson ghi789
One-to-many relationships:
A one-to-many relationship occurs when one record in a table is related to multiple records in another table. For example, you might have a table of customers and a table of orders, where each customer can place multiple orders. In this case, the customer and order tables would have a one-to-many relationship, with the customer table being the "one" side and the order table being the "many" side.
To create a one-to-many relationship between tables, you would use a foreign key in the "many" side table that references the primary key of the "one" side table. For example, you might have a primary key field called "ID" in your customer table and a foreign key field called "customer_id" in your order table. This would allow you to link each order to a specific customer.
Here's an example of a one-to-many relationship between the customer and order tables:
Customer table:
ID Name Address
1 John Smith 123 Main St
2 Jane Doe 456 Maple Ave
3 Bob Johnson 789 Oak St
Order table:
ID Customer_ID Order_Date Total
1 1 2021-01-01 100
2 1 2021 5
Many-to-many relationships:
Many-to-many relationships occur when multiple records in one table are related to multiple records in another table. For example, you might have a table of students and a table of courses, where each student can take multiple courses and each course can have multiple students. In this case, the student and course tables would have a many-to-many relationship.
To create a many-to-many relationship between tables, you would typically use a linking table that has foreign keys that reference the primary keys of the other two tables. The linking table is used to establish the relationship between the other two tables, and it typically contains additional fields that provide more information about the relationship.
Here's an example of a many-to-many relationship between the student and course tables:
Student table:
ID Name Address
Course table:
ID Course_Name Instructor
1 Mathematics 101 Professor X
2 Physics 201 Professor Y
3 History 301 Professor Z
Enrollment table:
To establish a many-to-many relationship between the student and course tables, we can add foreign keys to the enrollment table that reference the primary keys of the student and course tables:
ID Student_ID Course_ID Grade
1 1 1 A
2 1 2 B
3 2 2 A
4 2 3 C
5 3 1 B
6 3 3 A
Your business needs an operating system, not another tool.
Bring your operations, work and reporting into one system built around how your business actually works. Give your team clarity, automate repetitive work, provide clients with a professional portal, and track profitability in real-time—all without replacing tools you already rely on.
Join 1,000+ businesses using Noloco to improve margins and scale their operations with the speed and flexibility of AI and the reliability of a no-code business software.
Get Started for Free
Author
Gill O'Leary
Our recent posts
Explore all blog posts
Your most common
questions—answered!
Who is Noloco best suited to?
Noloco is perfect for small to medium-sized service businesses like consultancies, agencies, advisory firms, as well as  engineering and industrial services such as energy, construction, or any other operations-focused fields.
Not at all! Noloco is designed especially for non-tech teams. Simply build your custom system using a drag-and-drop interface. No developers needed!
Is my data secure?
Absolutely! Security is very important to us. Our access control features let you limit who can see certain data, so only the right people can access sensitive information
My business is growing fast—can Noloco keep up?
Can I make changes to my app after it’s been created?
Of course! You can adjust your app whenever needed. Add new features, redesign the layout, or make any other changes you need—you’re in full control.
Ready to boost
your business?
Build your custom tool with Noloco
