A client logs in to check on their project and lands on a page with another company’s logo, a URL they don’t recognize, and a menu that has nothing to do with the work you do for them. So they email you instead.
A white label client portal fixes that: clients log in on your domain, under your brand, and find what they need without asking. But branding is the easy part; the harder questions are whether you can control exactly what each client sees, and whether your team can run the work behind the portal in the same place. This guide compares five platforms on all three.
What is a white label client portal?
A white label client portal is a secure online space where your clients log in under your business’ branding, not the software provider’s. “White label” means the vendor’s name is removed from everything the client sees: the login page, the web address, the emails they receive, and any “powered by” badge.
Inside the portal, clients can typically:
- Check the status of their project
- Access files and deliverables
- Complete onboarding forms
- Approve work before it moves forward
- View reports built from their own data
- Upload documents you’re waiting on
- See invoices or account information
The hard part is keeping this consistent across every client, without a developer rebuilding the portal each time your process changes.
Why use a white label portal?
Because chasing clients is slow, unpaid work - simple! In the State of Client Collaboration 2026 survey by Progress Software (the company behind ShareFile), firms in accounting, law, financial services and healthcare said they spend nearly 20 hours a week collecting documents and signatures, following up, clarifying requests and tracking tasks. At $65 an hour, that’s a median of roughly $60,000.
A portal doesn’t eliminate client coordination, but it moves that back-and-forth into one place:
- Give clients one place to find everything. Project updates, files, reports, forms, and requests live in one login instead of five different tools.
- Show each client only the information they need. One client sees their project. They don’t see anyone else’s.
- Reduce “can you send that again” emails. If it’s already in the portal, they can go find it themselves.
- Let clients check progress without asking your team. Fewer status-check emails means fewer interruptions.
- Make your service feel like your own product. Your logo, your domain, your colors, no trace of the software underneath.
- Keep sensitive client information separate and secure. One client’s data isn’t visible to another, even inside the same portal.
If you already know you want to build one, see how a branded client portal builder works.
What features should a white label client portal have?
Most portals need to cover the same ground: security, permissions, integrations, reporting, file handling, forms, workflow automation, and branding. A few of these are worth more scrutiny than others.
To compare them properly, group the features by the three jobs the portal has to do:
1. Look like your business
- Your own domain, such as portal.yourcompany.com
- Your logo, colors, and fonts on every page, including the login screen
- Emails (invites, password resets, notifications) sent with your branding
- No vendor logo or “powered by” badge anywhere clients can see it
- A portal that works on a phone, since clients often check in on the go
2. Control what each client sees
- Role-based access, so your team, partners and clients each see a different slice of the system
- Record-level permissions, so two clients can share the same portal and never see each other’s data
- The option to hide internal fields, like notes or rates, from clients
- Easy client login, such as single sign-on
- Audit logs swhoing who accessed what
3. Run the work behind the portal
- A data layer you control, such as your existing database, spreadsheets, or CRM
- A view for your team across every client’s work, not just the client-facing pages
- Automations that run on client actions, like moving a job forward when a client approves it
How do you choose a white label client portal platform
Ask these questions of every platform you’re considering before you commit to it:
- Can you connect the tools and data you already use? Check whether you can point it at your existing CRM, database, or spreadsheets, rather than copying everything into a new system.
- Can each client see only their own information? Confirm you can control access by client, company, role, or project, not just by a single shared login.
- Can the portal match how your team actually works, including the exceptions? You should be able to build pages around your real onboarding, delivery, and approval process, not force your process to match the tool’s template.
- Can you brand the whole experience? And which plan removes the vendors’s branding? Custom domain, logo, colors, and emails, with no visible trace of the software provider.
- Can different clients get different experiences? One client might need project reports, another just onboarding tasks and documents.
- Will your team need a developer to maintain it? If every small change requires engineering time, the portal falls behind your business fast.
- How does pricing change as you add clients? This matters more for service businesses adding external users regularly than it does for internal-only tools.
- Can your team manage the work behind the portal in the same system, or will someone copy updates across from a spreadsheet?
The last question is the one most buyers skip. If the portal and your team’s workspace use different data, someone has to keep them in sync by hand, and clients end up seeing stale information.
How do off-the-shelf portals, custom builds, and AI portal builders compare?
AI means you no longer need a development team to get a portal built. What matters now is where the AI’s work ends up. There are three routes:
- Off-the-shelf portal software. Quick to set up, but you work inside the vendor’s template.
- Custom code, written by developers or generated by an AI coding tool. It fits exactly, but you own the code: hosting, logins, permissions, security fixes, and every change after launch.
- An AI portal builder. You describe the portal and AI builds it on a platform that already handles logins, permissions, hosting, and branding. What the AI builds shows up as pages, data, and access rules you can check and change without reading code.
| Off-the-shelf portal software | Custom code (developers or AI coding tools) | AI portal builder (Noloco) | |
| How you get the first version | Set up the vendor’s template | Developers write it, or an AI tool generates the code from a prompt | Describe it to Nola, which builds it on a ready platform |
| Fits your process | ⚠️ Only if your process matches the template | ✅ Built exactly as described | ✅ Built around how your team and clients actually work |
| Logins, hosting and security | ✅ Handled by the vendor | ⚠️ Yours to set up and maintain | ✅ Handled by the platform |
| Control over who sees what | ⚠️ Preset roles, often per client folder | ⚠️ Lives in the code, so someone technical has to check it | ✅ Permission rules you can see, test and change without code |
| Who can change it later | The vendor decides what changes | Someone who can read the code, or re-prompting that can break what already works | Your own team, by asking Nola or editing directly |
| Branding | ⚠️ Custom domain and removing vendor branding often on higher plans | ✅ Fully yours | ✅ Custom domain, logo and colors |
| Uses the data you already have | ⚠️ Usually means importing or duplicating data | ✅ If the connection is built and maintained | ✅ Airtable, Google Sheets, PostgreSQL or Noloco Tables |
| Work behind the portal | ⚠️ Often tracked in a separate tool | ✅ If built | ✅ Team views and workflows on the same data clients see |
| Ongoing cost | Subscription, often priced per client or seat | Developer time or AI tool fees, plus hosting and fixes | Subscription, see current pricing |
Off-the-shelf makes sense when your process is standard and you mainly need file sharing and messaging. Custom code makes sense when you have someone technical to own it long term. An AI portal builder fits when your process has exceptions, changes often, and the person who runs the operation needs to change the portal without breaking what already works.
For client portals, the permissions question decides it. A mistake there means one client sees another client’s data. Whichever route you choose, make sure you can see and test who has access to what before any client logs in.
What are the best white label client portal platforms in 2026?
Here’s how five platforms compare on the questions above.
| Platform | Best for | Lowest plan for a branded portal | Main strength | What to consider |
| Assembly | Service businesses managing recurring client work | Professional: custom domain and no Assembly badge, according to the listed plan details | Client management and recurring workflows are built in | Best suited to its built-in way of managing client work; unusual processes may need workarounds |
| Softr | Teams turning existing data into a client portal | Pro: custom domain and no Softr branding, according to the listed plan details | Fast portal building, AI-assisted creation and connections to existing data | Check the permission rules available on your plan before giving multiple clients access to sensitive data |
| Zite | Teams that want AI to generate a first version of an app | Pro: one custom domain and no Zite branding | Turn a plain-language description into a working starting point | Check that permissions, integrations and ongoing changes can support your real workflows before relying on it in production |
| SuiteDash | Businesses that want client management and business tools in one package | Start: branded portals and unlimited users, according to its pricing page | CRM, project management, invoicing and client portals in one suite | You get a broad set of built-in tools, but less freedom if your processes don’t fit the way the suite works |
| Noloco | Teams that need a branded client portal connected to complex workflows and internal operations | Build: custom domain and no in-app Noloco branding | Build a portal around your own data with AI, with client-specific permissions and the option to bring internal work into the same system | Best suited to businesses that need more than a place to share files; a simple download-and-message portal may not need this much flexibility |
Why is Noloco a good fit for teams with complex data and workflows?
When clients need to submit requests, approve work, check project progress or access their own reports, your portal needs to connect to the way your team actually works. Noloco lets you build that client experience around your data, with permissions that control what each person can see and do. And as your needs grow, you can bring more of your team’s work into the same system instead of adding another disconnected tool.
Noloco is built around your existing data and process, not a fixed template you have to adapt to. It covers all three jobs of a white label portal in one system.
- Look like your business. Put the portal on your own domain with your own logo and colors.
- Control what each client sees. Permissions go down to individual records and fields through Permissions, so a client only ever sees their own project, invoice, or report.
- Run the work behind the portal. Your team works in the same data as your clients, with its own views across every client’s jobs. Workflows handle the repetitive parts, onboarding steps, approvals, notifications, like notifying the account owner when a document is uploaded.
You can connect Airtable, Google Sheets, Postgres, MySQL, or Noloco’s own database, then build the portal around whatever structure that data is already in. If your client data already lives in Airtable, you can keep it there and build the portal on top, so clients never see the full base.
You can also describe the portal you need to Nola, Noloco’s AI builder, get a first version built from your data in minutes and reshape it. When your process changes, you edit the portal directly instead of building new integrations.
How do you build a white label client portal with Noloco?
- Connect your data. Point Noloco at your existing Airtable base, spreadsheet, or database, or start fresh with Noloco’s own database if you don’t have one yet.
- Build the client views. Use the AI builder to lay out what a client sees when they log in: status, files, reports, whatever’s relevant to them.
- Set permissions before you set branding. Decide who sees what, staff, contractors, and each client group, before you spend time on how it looks.
- Add your branding. Logo, colors, and a custom domain, so nothing points back to Noloco.
- Automate the repetitive parts. Set up workflows for onboarding steps, approval notifications, or status updates you’re currently sending manually.
- Test with one real client before rolling out to everyone. Confirm their permission level and their view actually work before it’s live for your whole client base.
What do real white label client portals look like?
GAP Consulting built a client portal and project management system on Noloco to fix a specific problem: client feedback was slow, project cycles dragged, and cash flow suffered because approvals required back-and-forth meetings and revisions.
With the portal, clients review and approve work on their own time, billing runs on an automated schedule, and the team gets notified when something changes. Because the client portal and the team’s project system run on the same data, nobody re-enters updates.
The result: cash flow doubled, billable hours rose by 50%, and project cycles got shorter. Read the full GAP Consulting story.
With Noloco, we doubled cash flow, reduced delays, and created a unique selling point for winning new clients” - Matthew Oates, GAP Consulting.
A white label client portal isn’t really about the branding, that’s just the visible part. What it actually does is move client coordination out of email and into one place both sides can check, which is where the real time and cost savings come from.
Assembly, Softr, Zite, and SuiteDash each solve a piece of that differently, built-in workflow, fast building on existing data, AI-generated first drafts, or an all-in-one suite. Before choosing, check all three jobs: how far the branding goes on the plan you’ll actually pay for, how precisely you can control what each client sees, and whether your team can run the work behind the portal in the same system.
Noloco is an AI portal builder built for that third job: the portal and the operation behind it run on the same data. If you’re ready to build, see how a branded client portal builder works.
A white-label client portal is a secure online space, branded as your own, where clients log in to see the files, updates, reports, or tasks relevant to them, instead of chasing that information across email and other tool.
How do I choose a white label client portal platform?
Check whether it connects to data you already have, controls access by client, matches your actual process, lets you brand the full experience, and doesn't require a developer for routine changes. Pricing that scales sensibly as you add clients matters too.
Is a white label client portal secure?
It should support role-based permissions so clients only see their own data, single sign-on rather than password-only login, and audit logs showing who accessed what. Ask any platform you're evaluating to confirm these directly rather than assuming.
How much does a white label client portal cost?
It varies widely by platform and by how many clients you're giving access to. White-label features, such as a custom domain and removing the vendor's branding, are often only on paid or higher plans. Compare the cost at the number of clients you expect to have in a year, not just today.
Noloco's Free plan supports unlimited team seats and 50 client seats at no cost; the Build plan starts at $79 a month for 10 team seats and 1,000 client seats (Noloco pricing, October 2026).
Can you build a white label client portal with AI?
Yes, and there are two ways to do it. AI coding tools generate an app's code from a prompt, which you then host, secure, and maintain yourself. AI portal builders use AI to set up the portal on a platform that already handles logins, permissions, hosting, and branding. For a portal that clients will use, the key check is the same either way: can you see and test exactly what each client has access to, without reading code?
How long does it take to launch a white label client portal?
A simple portal with one or two client views can go live in a day or two. One with detailed permissions, multiple client types, and workflow automation takes longer, budget for testing with a real client before rolling it out to everyone.
Why choose a white-label portal like Noloco over building from scratch?
Speed to launch — Build your portal in hours, not months, with the AI portal builder
Cost-effective — No need for a dev team; Noloco handles hosting, updates, and security.
Custom branding — Use your own domain, logo, and colors.
Feature-rich — Secure login, databases, workflows, file sharing, dashboards, and more.
Client-first UX — Noloco portals are built to look and feel like a natural extension of your brand.
- Best client portal platforms compareda deeper, tool-by-tool comparison for teams still narrowing down their shortlist.
- Client portal best practices for 2026what to get right once your portal is live, not just at launch.
- Client portal examples and ideasreal layouts and use cases to borrow from.
- GAP Consulting customer storyhow one consulting firm doubled cash flow and cut delays with a Noloco portal.
