Compare Tools
June 5, 2026
Best No-Code CRM Tools For Custom Workflows
Summarize with AI
Your CRM tells you a deal is closed. Your project tracker shows the kickoff is overdue. Your spreadsheet says you still haven't invoiced. Three tools, three sources of truth, zero confidence in any of them.
That's the moment most service business owners start searching for a no-code CRM they can actually shape around how they work, not the other way around. The problem is that most tools marketed as "flexible" are flexible in the same two directions: you can change the labels on the fields, and you can pick a color scheme.
This guide cuts through that. It covers what actually separates a genuinely customizable no-code CRM from one that just looks like it, and which tool makes sense for which type of firm.
TL;DR
  • No-code CRM tools vary widely in how deeply you can customize workflows, permissions, and client-facing views.
  • Airtable is strong on data structure but limited as a client-facing system without a front-end layer on top.
  • Softr and Stacker are good for simple client collaboration on basic pipelines, but hit ceilings fast when delivery, approvals, and invoicing need to connect.
  • Glide is best for mobile-first data apps, not full CRM or project tracking.
  • Quickbase is powerful but built for larger IT-led deployments, not service firms with a solo IT manager or small operations team.
  • Noloco is not just a CRM. It's an operating system for service businesses where sales, delivery, client approvals, and reporting all run from one place, without per-seat fees for clients.
What makes a no-code CRM actually custom?
The word "custom" gets used to mean two very different things. The first is surface customization: rename a field, add a column, change a pipeline stage. Almost every tool on this list does that.
The second is structural customization: change how data connects, control what each person can see and do, automate steps between delivery and billing, give clients their own view without exposing internal data. That's where the field narrows fast.
For a service business running 10 to 30 active client engagements at a time, the real question is: can the tool hold your actual process, or will you end up building workarounds in a spreadsheet next to it?
The five things worth checking before you commit to any no-code CRM:
  • When a deal closes, does work automatically move into delivery, or does someone have to copy information between tools?
  • Can you control what individual users or user groups can see and edit, down to the field level?
  • Can clients log in and see only their work, without seeing your team's internal data?
  • Can your team trust the system to move work forward automatically, or are people constantly checking spreadsheets and chasing updates?
  • Does the pricing model stay reasonable as your client count grows?
One stat worth knowing: according to Salesforce's 2023 State of CRM report, 66% of sales teams say their CRM is too complex for their actual needs. For service firms, the problem is usually the opposite: the tool is too rigid, not too complex.
At a glance: no-code CRM tools compared
Tool Best for Database integration Client portal Pricing model
Airtable Data-first teams who want structured records Native (own database) Limited without add-ons Per seat
Softr Simple client portals on Airtable data Airtable, Supabase Yes, template-based Per seat
Stacker Internal ops tools and simple CRMs Airtable, Google Sheets Basic Per seat
Glide Mobile-first data apps Google Sheets, Airtable, Glide Tables Limited Per seat
Quickbase Enterprise IT-led operations Native + integrations Yes Per seat, enterprise
Noloco Service firms connecting delivery, CRM, and client collaboration in one system Airtable, Noloco Tables, PostgreSQL, MySQL, Google Sheets Yes, branded + role-based Flat active user pricing
1. Airtable
Airtable is the most widely used no-code database in this category, and for good reason. Its linked records, views, and formula fields make it one of the most structured ways to hold CRM data without writing a line of code. If you want to track contacts, deals, and project status in a clean relational structure, Airtable handles that well.
Where it gets complicated is when you need to show that data to clients, or control what different team members can see. Airtable's sharing settings are blunt: you can share a base, a view, or a form, but you can't give someone a login that shows them only their records. Its interface builder adds some of that functionality, but still has limits around layout flexibility, granular permissions, and multi-step workflows.
Many service firms use Airtable as the data layer and add a purpose-built front-end on top. Noloco connects directly to your existing Airtable base and adds proper permissions, client-facing views, and workflow automations without requiring you to migrate your data. You keep the Airtable structure you've built; you get the interface layer on top.
Best for: Teams already on Airtable who want to structure their CRM data before adding a client-facing layer.
Ceiling: Client permissions and branded client portals require a separate tool.
2. Softr
Softr is probably the most direct competitor to the "build a client-facing portal on top of Airtable" use case. It gives you pre-built blocks (tables, forms, charts, dashboards) that connect to your Airtable or Supabase data, with user roles that control what each person sees.
For simple setups, it works well. A deal tracker your team manages, with a client login that shows their project status: Softr can do that out of the box. Where it runs into trouble is the moment your process gets more complex than what the blocks were designed for. Custom page layouts are limited. Permissions are managed page by page, which becomes exhausting as the user list grows. Any change to the live app risks breaking what clients see, because there's no staging environment.
Softr's pricing is also per seat, which starts to add up quickly once you're inviting clients in.
Best for: Small teams who want to stand up a simple client portal on existing Airtable data without building from scratch.
Ceiling: Complex page layouts, data-level permissions, and staging environments for testing changes safely.
3. Stacker
Stacker connects to Airtable or Google Sheets and lets you build internal tools and simple CRM-style apps without code. The setup is fast: connect your data source, choose which fields to show, set up user roles. For small teams who want to turn a spreadsheet into something that looks like proper software, it's a quick win.
The limitation is depth. Stacker works well for structured data display and simple record management, but its workflow automation is light, and its client portal capabilities are basic. If you're tracking a linear sales pipeline, it's fine. If you're tracking delivery progress, invoicing status, and client communication in the same system, you'll outgrow it quickly.
Best for: Ops teams who want to put a clean interface on top of an existing spreadsheet or Airtable base with minimal build time.
Ceiling: Multi-step workflows, client collaboration, and anything that requires logic beyond simple record display.
4. Glide
Glide is built for mobile-first apps. Its strengths are in taking Google Sheets or Airtable data and turning it into a clean, app-style interface that works on a phone. Field teams, inspection checklists, event check-ins: Glide is genuinely good at those use cases.
For CRM and client management in a service business context, it's not the right tool. Backend logic is limited, which means complex relational data and conditional workflows tend to break down. It's also built around a different mental model than what most service firm owners have in mind when they're searching for a no-code CRM.
Best for: Mobile data collection apps and simple field-use tools, not client-facing CRM or delivery management.
Ceiling: Almost everything a service firm CRM needs: complex relationships, role-based access, client portals, and workflow automation.
5. Quickbase
Quickbase is a low-code platform with serious depth: relational data, role-based permissions, workflow automation, and integrations with enterprise systems. For a 200-person professional services firm with a dedicated IT team, it's a legitimate option.
For a 10 to 50 person service business without in-house developers, it's a mismatch on multiple dimensions. The implementation typically requires a consultant or a technical project lead. The pricing is enterprise-tier. And the learning curve for non-technical operators is steep. Quickbase earns its place on this list because it comes up in searches, but it's not what most founders in this category actually need.
Best for: Larger, IT-led operations that need enterprise-grade data governance and are willing to invest in implementation.
Ceiling: Accessible to non-technical founders; affordable for teams under 50 people.
6. Noloco
Noloco is built specifically for service businesses that need more than a simple pipeline tracker: a connected system where the CRM, the delivery workflow, and the client portal all run on the same data, without rebuilding every time something changes.
You can connect Noloco to your existing Airtable base and add the interface, permissions, and client collaboration layer on top, no data migration needed. Or you can run your full data model inside Noloco Tables. Either way, the result is one system where your team tracks deals, manages delivery, and gives clients access to only what they need to see.‍
Because permissions are applied at the field level, not just the page level, teams can safely collaborate with clients, vendors, and partners in the same system. Clients only see their own work. Internal teams keep access to operational data. As the business grows, the system remains safe to delegate and difficult to break.
Pricing is flat active-user pricing, not per seat. One customer, Red Rock Entertainment, cut their annual software bill by 80% (saving roughly $30,000 a year) after consolidating 100 users off per-seat tools into Noloco.
Noloco also ships with Nola AI, which creates tables, relationships, pages, and workflows through natural language. The time from "I want to build this" to "this is live" drops from weeks to hours for most service firm setups.
Best for: Service businesses that need their CRM, delivery tracking, and client portal to run from the same place, with real role-based permissions and no per-seat fees for clients.
Ceiling: If you need deep low-level design control or are building a consumer-facing marketing site rather than an operational system, other tools may offer more visual flexibility.
How do these tools compare on the features that matter for service firms?
Feature Airtable Softr Stacker Glide Quickbase Noloco
Custom data model ✅ Yes ⚠️ Via Airtable ⚠️ Via Airtable/Sheets ⚠️ Basic ✅ Yes ✅ Yes
Spreadsheet/DB integration Native Airtable, Supabase Airtable, Sheets Sheets, Airtable Native + integrations Airtable, Sheets, PostgreSQL, MySQL
Branded client portal ❌ No ⚠️ Template-based ⚠️ Basic ❌ No ✅ Yes ✅ Yes, fully branded
Field-level permissions ❌ No ❌ Page-level only ❌ Page-level only ❌ No ✅ Yes ✅ Yes
Staging environment ❌ No ❌ No ❌ No ❌ No ✅ Yes ✅ Yes
Workflow automation ⚠️ Basic ⚠️ Basic ⚠️ Basic ⚠️ Basic ✅ Advanced ✅ Advanced
Per-seat pricing for clients Yes Yes Yes Yes Yes No (flat active user)
How do you set up a no-code CRM for a service business?
Most service firms can have a working CRM live in under a day. The steps are the same regardless of which tool you choose.
  1. Map your data before you build anything. Write down the three or four record types you actually track: clients, deals, projects, invoices. Sketch how they connect. A deal belongs to a client. A project is created when a deal closes. This sketch becomes your data model.
  2. Connect your existing data source or start fresh. If you're on Airtable or Google Sheets, connect it directly rather than rebuilding from scratch. If you're starting clean, most no-code tools let you import a CSV or describe your structure in plain language.
  3. Set up who sees what before you invite anyone. Decide what your team sees vs what clients see before a single person logs in. Retrofitting permissions after the fact is the most common source of data leaks and broken setups.
  4. Build the client-facing view last, not first. Get your internal team workflow right first. What clients see should be a filtered, branded version of what already works internally, not a separate thing you build and then try to connect.
  5. Automate one handoff, not everything. Pick the single step that costs your team the most time, typically the notification when a deal closes or a project status changes, and automate that first. Expand from there once the core is stable.
With Noloco, steps one and two collapse into a single session. Nola AI creates the tables, relationships, and pages from a plain-language description of how your firm works. Most teams have a working base up in a few hours, not a few weeks.
How do you know which tool is the right fit for your firm?
The honest answer is that it depends on what's actually broken in your current setup. Different firms hit different ceilings.
If your data is already well-structured in Airtable and your main problem is that clients can't see it safely, the fastest path is adding a purpose-built front-end on top rather than migrating everything. Softr is quicker to set up for a simple portal; Noloco gives you more depth when you need it.
If you're still running your CRM in a spreadsheet and feel the seams every time you add a new client or hire someone new, a tool that lets you structure your data while building the interface at the same time will save you the double-migration later. Noloco's AI setup closes that gap faster than building from a blank canvas.
If you're a Glide or Softr user who's hit the ceiling on what you can build, the data you've already structured travels with you. The switch is a UI and workflow migration, not a data migration.
If someone on your team is pitching Quickbase, ask who is going to implement it and maintain it. If the answer is a consultant or an external developer, factor that into the real cost before comparing it to tools designed for non-technical operators.
No-code CRM tools have come a long way. The basics, tracking contacts, logging deal stages, managing a pipeline, are now table stakes across almost every tool in this category.
What separates them is what happens next. When a deal closes, can your system connect that to a project record, assign a team member, send a client login, and trigger the first invoice, without you stitching four tools together manually? That's the real test.
For service businesses that sell delivery and expertise, the CRM is only one piece. The firms that grow without drowning in admin are the ones that build a system where the CRM, the delivery workflow, and the client experience run from the same place. That's what Noloco is built for.
FAQ
What is a no-code CRM?
A no-code CRM is a system for tracking client relationships, deals, and communication that you can set up and change without writing code. Unlike off-the-shelf CRMs like Salesforce or HubSpot, no-code CRMs let you structure the tool around your own process rather than adapting your process to their templates.
What is the difference between a no-code CRM and a low-code CRM?
No-code tools are designed for non-technical users: you build with visual editors, drag-and-drop builders, and pre-built components. Low-code tools assume some technical knowledge and allow you to write small amounts of code to extend what the visual builder can do. Quickbase is low-code. Noloco, Softr, and Glide are no-code. For most service business owners, no-code is the right starting point.
Can I connect a no-code CRM to my existing spreadsheets or Airtable base?
Yes, most tools on this list do that. Softr, Stacker, and Noloco all connect directly to Airtable and Google Sheets. Noloco also supports PostgreSQL and MySQL for firms with more advanced data setups. If your data is already in Airtable, you don't need to migrate it: you connect the tool and build the interface and workflows on top.
What should I look for in a no-code CRM for a service business?
The five things that tend to matter most: the ability to link CRM data to project and invoice records without a separate automation tool; field-level permissions that control what each person can see and edit; a client portal that shows clients only their own work; workflow automation that fits your actual process rather than a preset template; and a pricing model that doesn't penalize you for inviting clients into the system.
Is Noloco a CRM?
Noloco is more than a CRM. It's an operating system for service businesses that lets you build a connected CRM, delivery tracker, and client portal in one place. You can set up a contact and deal tracking system that looks and works like a proper CRM, and connect it directly to your project and billing data. Many service firms use Noloco as the single system where sales, delivery, and client collaboration all live.
How much does a no-code CRM cost?
It varies widely. Most tools charge per seat, which means your costs grow every time you invite a team member or a client. Softr, Glide, and Stacker all use per-seat models. Noloco uses flat active-user pricing, which tends to be significantly cheaper once your client count grows. The real cost comparison isn't just the platform fee: it's the platform fee plus the time spent building and maintaining the system, plus the tools you can retire by consolidating.
Your business needs an operating system, not another tool.
Bring your operations, work and reporting into one system built around how your business actually works. Give your team clarity, automate repetitive work, provide clients with a professional portal, and track profitability in real-time—all without replacing tools you already rely on.
Join 1,000+ businesses using Noloco to improve margins and scale their operations with the speed and flexibility of AI and the reliability of a no-code business software.
Get Started for Free
Author
Our recent posts
Explore all blog posts
Your most common
questions—answered!
Who is Noloco best suited to?
Noloco is perfect for small to medium-sized service businesses like consultancies, agencies, advisory firms, as well as  engineering and industrial services such as energy, construction, or any other operations-focused fields.
Not at all! Noloco is designed especially for non-tech teams. Simply build your custom system using a drag-and-drop interface. No developers needed!
Is my data secure?
Absolutely! Security is very important to us. Our access control features let you limit who can see certain data, so only the right people can access sensitive information
My business is growing fast—can Noloco keep up?
Can I make changes to my app after it’s been created?
Of course! You can adjust your app whenever needed. Add new features, redesign the layout, or make any other changes you need—you’re in full control.
Ready to boost
your business?
Build your custom tool with Noloco
