Practice management tools for UK agencies: a 2026 guide | Noloco
UK agencies lose nearly £19,000 a year to admin overhead. Here is how to connect workflows, resource planning, time tracking, and billing in one system.
Marta PrunésContent Marketing Manager11 min read
A twelve-person consultancy in Leeds was running its operations across four tools: a project tracker, a time logging app, a separate invoicing platform, and a shared spreadsheet that someone updated manually every Friday afternoon. When a client asked for a progress report on a Thursday, the account lead had to pull data from three different places, reconcile the numbers, and write a summary by hand. The whole thing took ninety minutes. Nobody felt that was a good use of their time. Nobody knew how to fix it.
This is the most common operational pattern in UK agencies and professional service firms: the tools work individually, but they do not talk to each other, so the people in the middle end up doing the connecting. That manual connecting is where hours disappear, where errors creep in, and where the firm quietly loses money it has already earned.
This article explains what practice management actually requires for a growing UK agency, why most tools fall short, and how Noloco’s Agency Operating System brings workflows, resource planning, time tracking, and billing into one place without a development project or a rigid implementation process.
Why do UK agencies struggle with practice management tools?
The answer is not that agencies are disorganised. Most agency owners are perfectly capable of running a tight operation. The problem is structural: the tools available to them were built for a different type of business.
PSA (Professional Services Automation) tools like Scoro, Productive, and Teamwork are the closest category match to what an agency needs. They handle project management, time tracking, and financial reporting in one place. But they enforce a predefined way of working. If your delivery model does not match the tool’s assumptions about how projects are structured, how resources are assigned, or how billing cycles work, you end up adapting your process to fit the software rather than the other way around. Most agencies try this once, hit a wall within six months, and go back to their spreadsheets.
Generic project management tools are more flexible but built for internal teams, not for service delivery. They have no meaningful client-facing layer, no billing logic, and no concept of utilisation or project profitability. Adding those things requires integrations, which require maintenance, which requires someone on your team to keep the whole thing working.
The result is what most UK agencies are actually running: a collection of tools that each do one thing adequately, connected by manual processes and one person who holds all the institutional knowledge in their head.
What does a proper practice management setup actually need to do?
Before evaluating any tool, it helps to be precise about what practice management actually covers for a UK agency. It is not just project tracking. It is the full operational loop from when a client engagement is agreed to when the invoice is paid and reconciled.
A functional practice management setup needs to handle four things reliably.
Workflow management. How work gets scoped, assigned, tracked, and delivered. This includes the internal process from briefing to delivery, the handoff points between team members, the approval steps before work goes to a client, and the record of what was agreed versus what was delivered.
Resource planning. Who is working on what, for how many hours, across how many active engagements. For a UK agency, this means understanding utilisation at the team level (are people fully allocated?), at the project level (is this engagement running over the scoped hours?), and at the firm level (do we have capacity to take on new work?).
Time tracking. Logged against the right project, the right client, and the right phase of delivery. Time that is logged accurately is the foundation for project profitability reporting and for accurate invoicing. Time that is logged in a separate tool and exported monthly is not the same thing.
Billing and invoicing. In the UK context this includes VAT-compliant invoicing, the ability to bill against milestones or time spent depending on the engagement type, and a clear record of what has been invoiced, what has been paid, and what is outstanding. For firms working with clients under IR35 considerations or with contractors, the billing structure needs to be flexible enough to reflect how the work is actually resourced.
The table below maps these four areas against the tools most UK agencies are currently using to cover them.
Practice management need Spreadsheets Generic PM tools PSA tools Noloco Agency OS
Workflow management Manual, breaks under volume Good internally, no client layer Strong but rigid; forces a template Built to match your process, not a template
Resource planning Fragile; one formula error affects everything Basic task assignment; no utilization view Strong at scale; complex to configure Solid for firms up to 50 people; visual and configurable
Time tracking Separate spreadsheet; rarely accurate Add-on feature; not linked to billing Built in and linked to financials Built in; linked directly to project and billing records
Billing and invoicing Manual; error-prone Not included; requires integration Included; rigid billing structures Flexible billing tied to time logs or milestones
Client-facing portal None None or basic link sharing Limited or charged per external seat Included; granular permissions, branded
Setup and configuration Immediate but fragile Days to weeks Weeks to months; often requires a consultant Days; no-code, no implementation project
How does Noloco handle workflow management for UK agencies?
Noloco is built around the idea that no two agencies deliver work the same way. Some firms work in fixed-price retainers with monthly deliverable sign-offs. Others run project-based engagements with milestone billing and weekly status updates. Others mix both, depending on the client. A practice management tool that enforces one model forces the firm to either simplify how it works or maintain workarounds outside the system.
Noloco’s Interface Builder lets agency ops teams build workflows that match how they actually deliver work. The data model (what information the system tracks), the pages (what each team member sees), and the automations (what happens when a status changes or a deadline approaches) are all configurable without writing code.
In practice, this means:
A briefing submitted by a client lands in a structured intake form with all the information your team needs to start work. It does not arrive as an email that someone has to manually convert into a task. The brief becomes a record in the system, with a status, an owner, a deadline, and a linked client.
When the status changes (from briefed to in progress, from in progress to in review, from in review to approved), the right people are notified automatically. The client sees the outcome of the approval. They do not see the internal review process. Your account manager does not have to send a manual update.
When a deliverable is approved, the record moves to billing. The hours logged against it are already there. The invoice can be generated from the same system rather than switched to a separate tool.
This is what a connected workflow looks like in practice. Not a Gantt chart. Not a shared Notion doc. A system where one action moves the work forward and the right people are told what they need to know.
How does resource planning work for a growing UK agency?
Resource planning is where most UK agencies have the least visibility. They know their team is busy. They do not always know whether “busy” means 80% utilised or 110% utilised, and they do not know which clients are consuming disproportionate time relative to what was scoped.
In Noloco, resource planning is built on top of the same data that drives workflow and time tracking. Each team member’s logged hours sit against the projects they are working on. Each project has a scoped hours figure. The difference between scoped and logged is the over- or under-run, visible at the project level and at the team level.
This means a director reviewing the week’s workload can see:
  • Which projects are running over scope and need a conversation with the client or a scope change request.
  • Which team members are close to or over their allocated hours for the month.
  • Whether there is capacity to take on a new engagement or whether committing to one would require either additional resource or a push on an existing deadline.
For UK agencies managing contractors alongside permanent staff, Noloco supports different resource types within the same system. A contractor’s time is logged against the same projects as an employed team member, but the billing rate, the capacity limit, and the cost structure can differ. This matters for accurate project profitability reporting and for firms that need to track whether contractor costs are sitting within the budget agreed with the client.
How does time tracking connect to billing in Noloco?
Time tracking only has value if it connects to something. Logged hours that sit in a separate spreadsheet and get exported once a month are not operational data. They are historical records that arrive too late to change anything.
In Noloco, time is logged directly against project records by the team member doing the work. The log is linked to the client, the project phase, and the deliverable. When a project moves to billing, the hours are already there. There is no export, no reconciliation, no “can you send me your timesheet for last month.”
For UK agencies billing on time and materials, this means the invoice reflects the actual hours logged against the engagement, pulled directly from the system. For agencies billing on milestones, the completed milestone record is already linked to the hours consumed, so the project profitability calculation happens automatically rather than at the end of a month when someone finally gets around to the comparison.
VAT-compliant invoicing, flexible billing structures (retainer, milestone, time and materials, or a mix), and a clear outstanding payments view are all part of the same system. An ops manager can see at any point which clients have outstanding invoices, which projects have been delivered but not yet billed, and where the gap is between hours sold and hours logged.
How does client collaboration fit into a UK agency’s practice management system?
Client collaboration is where most practice management tools stop short. They handle the internal side well enough, but the moment a client needs to see something, the system falls back to email or a shared folder.
Noloco includes a branded client portal as part of the same system, not as a separate product. Each client logs in to their own view. They see their projects, their documents, their outstanding approvals, and their invoices. They do not see other clients’ data, internal costs, team notes, or any information that is not relevant to them.
For UK agencies managing clients who expect a professional, structured experience (and increasingly, larger clients and enterprise buyers in the UK do expect this), the portal is part of what makes the relationship feel different. The client is not chasing updates by email. They are logging in and seeing the current status of their work, the documents waiting for their approval, and the invoices due.
Permissions are configured at the field and record level, which means what a client can see and what they can do is controlled precisely. A client can submit a scope change request but cannot approve their own deliverable. They can view their invoice history but cannot see the internal cost breakdown behind it. This is not just a security concern. It is about presenting a professional, organised experience to people who are paying for expertise, not for access to your internal operations.
What does the setup process look like for a UK agency?
One of the consistent objections to adopting a new practice management system is the implementation risk. UK agencies that have been through a PSA implementation know what it costs in time, money, and disruption. A six-month rollout with a third-party consultant, a data migration, and a retraining programme is not something most founders want to repeat.
Noloco is designed to avoid that pattern. There is no implementation project. The system is configured by the ops team, not by a vendor or a specialist, using a visual builder rather than code. Agency-ready defaults mean the core structure (clients, projects, team, time, billing) is already there when you start. You adapt it to your process rather than building from scratch.
For a UK agency moving from spreadsheets, the realistic setup timeline is one to two weeks for a working system covering workflows, resource planning, time tracking, and billing. For a firm migrating from a PSA tool, the data model already exists. It is a configuration exercise, not a rebuild.
The table below shows what a typical Noloco rollout looks like for a UK agency at different firm sizes.
Firm size Starting point Typical setup time What gets built first
5 to 10 people Spreadsheets and email 3 to 5 days Client and project records, time logging, basic billing view, client portal for status updates
10 to 25 people Generic PM tool plus separate invoicing 1 to 2 weeks Full workflow management, resource allocation view, time tracking linked to billing, approval workflows, client portal
25 to 50 people PSA tool or fragmented stack 2 to 3 weeks Full practice management setup including multi-tier permissions, contractor resource tracking, milestone and retainer billing, branded client portal with document management
Noloco does not charge per external seat for client access. For UK agencies with growing client rosters, this matters. The pricing does not compound every time you add a new client to the portal.
The firms that run well are not necessarily the ones with the most sophisticated tools. They are the ones where the tools they have are actually connected, where the data from delivery feeds into billing without manual intervention, where clients have a professional place to log in rather than an email chain to dig through, and where the ops team is not the human glue holding everything together.
UK agencies are losing real money to admin overhead. Nearly £19,000 per year in leadership time alone, according to NerdWallet’s 2025 survey of UK business owners. Most of that is recoverable with the right system.
Practice management is not a software problem. It is a design problem. The question is whether the system is designed around how the firm actually works, or whether the firm is working around a system that was designed for someone else.
Noloco gives UK agencies the tools to design it properly, without a development project, without rigid templates, and without per-seat fees that make client collaboration expensive as you grow.
Book a demo to see how Noloco runs UK agency operations
What are practice management internal tools for UK agencies?
They are the systems a UK agency uses to manage its operational core: how work gets scoped and tracked, how team members are allocated across projects, how time is logged against client engagements, and how that time feeds into invoicing and profitability reporting. The best setups connect all of these in one place rather than running separate tools for each function.
Why do UK agencies find practice management software difficult to implement?
Most practice management tools in the UK market are either PSA platforms (which are powerful but rigid and require lengthy implementations) or generic project management tools (which handle internal task tracking but were never built for client-facing service delivery). Neither fits a growing agency cleanly without significant adaptation. The implementation risk and the cost of getting it wrong are both high.
How does Noloco differ from PSA tools used by UK agencies?
PSA tools enforce a predefined delivery model. Agencies adapt to the tool. Noloco adapts to the agency. The data model, the workflows, the pages, and the automations are all configurable to match how the firm actually delivers work. Noloco also includes a branded client portal as part of the standard setup, whereas most PSA tools either lack client portals entirely or charge per external seat for access.
Does Noloco handle VAT-compliant invoicing for UK agencies?
Noloco supports flexible billing structures that can be configured to meet UK invoicing requirements, including VAT, milestone billing, time and materials, and retainer arrangements. The billing records are linked directly to time logs and project records, so there is no separate reconciliation step.
How long does it take to set up Noloco for a UK agency?
For a firm moving from spreadsheets, a working system covering workflows, time tracking, and billing typically takes three to five days for a smaller team and one to two weeks for a firm between ten and twenty-five people. There is no implementation project, no external consultant required, and no code involved. The configuration is done by the ops team using a visual builder.
What happens to client access pricing as a UK agency grows?
Noloco does not charge per external seat for client access. Client users are included in the plan, which means adding new clients to the portal does not increase the monthly cost. For UK agencies with growing client rosters, this is a meaningful difference from PSA tools and project management platforms that bill per external user.
