Airtable & spreadsheets
Why agencies replace spreadsheets with no-code systems
Growing agencies keep hitting the same wall with spreadsheets. Here's why it happens and how no-code systems give agencies a way to run operations that scales with them.
Boglarka HeraGrowth Manager6 min read
Every agency starts the same way. A founder builds a spreadsheet to track clients, another for project status, a third for time and billing. It works. Then the agency adds a fifth client, then a tenth, then a fifteenth, and the spreadsheets that once felt like control start to feel like a second job.
If you’re the person holding that system together, you already know the moment: a formula breaks right before a client call, or two team members overwrite each other’s updates, or you’re the only one who understands why a tab is color coded the way it is. None of that means you built it wrong. It means the tool was never designed to run an operating business.
What signs show a growing agency has outgrown spreadsheets?
The signs usually show up in the same order. First, someone breaks a formula and nobody notices until a client-facing number is wrong. Then delegation starts to feel risky, because only the founder fully understands how the sheet works. Eventually, the agency is paying for three or four SaaS tools on top of the spreadsheets, and still reconciling everything by hand at the end of the week.
This isn’t a rare situation. 90% of organizations are still relying on outdated spreadsheets for some of their most vital business data, according to 2025 research from AutoRek covered by TechRadar. The same research found that 82% of businesses have automation on their roadmap, but only 43% plan to act on it within the next year. Most agencies know the spreadsheet stage is temporary. Few have a clear next step.
Why do spreadsheets break down as agencies scale?
Spreadsheets aren’t a bad tool. They’re flexible, familiar, and cheap to start with. The problem is what happens when an agency grows past the size a spreadsheet was ever meant to support.
Three things tend to break first:
  • Fragility. One wrong formula, one accidental overwrite, and a critical workflow stops working. There’s no built-in way to protect the parts of the sheet that matter most.
  • Founder dependency. If you’re the only person who understands the logic behind the tabs, delegation becomes risky. The agency can’t grow past what one person can personally hold together.
  • Client experience. Spreadsheets can’t produce a branded portal or a real-time view for a client. When a $50,000 engagement is tracked in the same tool as a personal budget, it shows.
None of this means the founder built the wrong thing. It means the spreadsheet was asked to become something it was never designed to be: an operating system for a growing business.
How do spreadsheets compare to no-code operations systems?
Capability Spreadsheets No-code operations systems
Data protection ❌ Anyone with edit access can change any cell ✅ Field and record level permissions
Safe delegation ⚠️ Works only if the team knows the logic behind the sheet ✅ Structured workflows the team can run without the founder
Client visibility ❌ No branded, role-based client view ✅ Branded client portals with permission-based access
Automation reliability ⚠️ Formulas and manual reminders that break when one cell changes ✅ Automations that don’t depend on a single cell staying intact
Real-time reporting ❌ Requires manual reconciliation across tabs and tools ✅ A single live dashboard across delivery and revenue
Setup time ✅ Immediate, no learning curve ✅ Minutes to hours with agency-ready templates, not months
How do no-code systems fix what spreadsheets can’t?
A no-code operations system doesn’t ask an agency to start from a blank slate. Most connect directly to the data agencies already have, whether that’s Google Sheets or an Airtable base, and add the structure on top: permissions, client-facing interfaces, and automated workflows that don’t break when one field changes.
This is why the near-miss moment, when a formula breaks or a client sees the wrong number, is usually when agencies start looking seriously at alternatives. The data and process logic already exist. What’s missing is a layer that makes them safe to delegate and professional to show clients.
Redrock Entertainment, a service business running Noloco on top of an existing Airtable base for more than 100 users, cut software costs by 60% after consolidating its operations into one system. As Jesse VanDenGooy, Technology Solutions Architect at Redrock Entertainment, put it, the shift meant the team stopped patching together separate tools and started running one connected system instead.
What should agencies look for in a no-code operations system?
Not every no-code tool solves the same problem. Before picking one, an agency should check for a few specific things.
  • Granular permissions. Can you control access at the record and field level, not just by giving someone a full seat or none at all?
  • Client-facing interfaces. Can clients see a branded, role-specific portal, not just a shared spreadsheet link?
  • Workflow depth. Does the automation layer handle multi-step processes, or only simple triggers?
  • No migration requirement. Can it connect to data you already have, or does adopting it mean starting over?
  • Built for how services firms actually work. Does it start from defaults built for client delivery, or from a blank canvas meant for any use case?
How does Airtable fit into this transition?
A meaningful share of growing agencies are already on Airtable, and that’s not something to walk away from. Airtable is a strong data layer. Where agencies tend to hit a ceiling is when they need permissions Airtable can’t cleanly enforce, a branded client-facing interface, or workflow depth beyond what Airtable Automations covers.
This is where Noloco’s Airtable integration comes in. Agencies keep their Airtable base as the data layer and add Noloco on top for real interfaces, granular permissions, and client portals. There’s no migration project and no starting from scratch. For agencies that have outgrown Airtable as a primary operations database entirely, the same platform can also become the new source of truth, with Airtable kept around for narrower use cases if needed.
How much does switching from spreadsheets actually cost?
The upfront cost of staying on spreadsheets looks like zero, which is part of why so many agencies delay the switch. But the real cost is hidden: founder hours spent on admin, time lost reconciling numbers across tools, the risk of errors in front of a client, and the client churn that follows a visibly unprofessional delivery experience.
Most no-code systems built for service businesses come with agency-ready templates, which means first value in minutes rather than a six-month implementation project. The switch is closer to adding a layer on top of what already exists than tearing it down and rebuilding.
Not all no-code options solve this the same way. Here’s how the common ones compare.
Approach Starting point Client-facing portals Permission granularity Time to first value
Airtable Interfaces Blank canvas, built for internal views ⚠️ Limited layout flexibility, not built for client-facing use ⚠️ Base-level sharing, not granular record or field control ✅ Fast for simple internal views
Generic no-code app builders (Glide, Softr) Blank canvas, general purpose ⚠️ Possible to build, but requires assembling from scratch ⚠️ Varies by tool, often limited backend logic (especially Glide) ❌ Weeks of build time, no agency-specific defaults
Noloco Pre-configured agency workspace: clients, engagements, work, money ✅ Branded, permission-based client portals out of the box ✅ Field and record level permissions ✅ Minutes to hours with agency-ready templates
Spreadsheets aren’t the enemy. They got most agencies to where they are today. The problem shows up when an agency keeps growing and the spreadsheet doesn’t grow with it: it stays fragile, stays dependent on one person, and never produces the kind of client experience that matches what the agency actually delivers.
No-code systems close that gap without forcing a rebuild. They start from the data and process logic an agency already has, and add the structure, permissions, and client-facing layer that spreadsheets were never built to provide. Noloco’s Agency Operating System is built specifically for this transition, with defaults for clients, projects, and delivery already in place.
What is an internal operations tool?
An internal operations tool is the system a business uses to run its day-to-day work: tracking clients, projects, time, and finances in one place instead of across separate documents.
How do I know if my agency has outgrown spreadsheets?
Common signs include broken formulas causing client-facing errors, delegation feeling unsafe because only one person understands the system, and spending significant time each week reconciling data across tools.
Can I keep using Airtable if I switch to a no-code system?
Yes. Many no-code platforms, including Noloco, connect directly to an existing Airtable base rather than requiring a migration, so the data stays in place while the interface and permissions layer gets added on top.
How long does it take to move off spreadsheets?
With agency-ready templates, initial setup can take minutes to hours rather than months, since the system starts from a preconfigured structure instead of a blank canvas.
Do I need engineers or developers to set up a no-code system?
No. No-code platforms are built for non-technical users, and most agency teams can be operational within a day.
Is a no-code system more expensive than spreadsheets?
Spreadsheets have no direct cost, but the hidden costs (founder admin time, manual reporting, errors, client churn) often outweigh the price of a dedicated system once an agency is growing.
Boglarka Hera
Growth Manager at Noloco
