I get asked some version of this question almost every week now: “We’re deciding between Zite and Base44, what’s actually different once you get past the demo?”
The honest answer starts with pricing, not capability. Both Zite and Base44 are genuinely capable AI app builders, and both can run real, production apps, not just demos. Zite markets itself directly at client portals and has an Enterprise tier built around exactly that. Base44 has real businesses running on it, including teams that have scaled to meaningful revenue without a rebuild. Neither is a toy.
Where the two differ most in practice, and where teams most often get surprised, is the credit system both run on. It’s the part of the pricing model that’s hardest to estimate upfront, and it’s also the clearest practical difference from how Noloco is priced. That’s where we’ll start below, alongside an honest look at what each platform handles well and what to plan for as usage grows.
I’m the founder of Noloco, so take this comparison knowing I have a stake in where you land. I’ve tried to represent Zite and Base44 fairly below, because they’re both good at what they do well, and AI-assisted building is something we’re investing in too, not something we’re positioned against. The honest difference isn’t AI versus no AI. It’s what the pricing model and the foundation look like once an app is actually in use.
What does each platform actually do?
What is Zite?
Zite is an AI-powered no-code app builder. You describe what you want in plain language, and it generates a working application: database, authentication, basic workflows, and a UI you can publish immediately. After that first generation, Zite lets you refine the app through a visual editor rather than only through more prompts, which is a meaningful difference from pure code-generation tools. Zite markets itself directly for client portal and Enterprise use cases, and agencies do build real client-facing systems on it.
Zite’s pricing includes unlimited users on every plan, including the free one. The Free plan is $0/month with limited credits and a 5,000 record database cap. Pro is $15/month (billed annually) with 100,000 records. Business is $39/month (billed annually) with 250,000 records and unlimited custom domains. Enterprise tier adds SOC 2 Type II, SSO, audit logs, and data residency choice between the US and EU. For a wider look at Zite’s strengths and limitations, see our full Zite Alternatives roundup.
What is Base44?
Base44 is also an AI-powered app builder that generates a full-stack application (frontend, backend, database, auth) from a natural language prompt. It was acquired by Wix in 2025. Base44’s model leans more heavily on a credit system: message credits for prompting the AI, and integration credits for what your app’s users actually trigger once it’s live. Real businesses run on it, including teams that have scaled to meaningful revenue without rebuilding the product. some users building at higher volume report hitting rate-limit and webhook-processing ceilings as their apps grow, which is worth weighing if your app will depend on background jobs or heavy traffic.
Base44 has five tiers: Free ($0, 25 message credits/month), Starter ($16/month annual), Builder ($40/month annual), Pro ($80/month annual), and Elite ($160/month annual). Paid plans support code export, including export to GitHub on Builder tier and above. At the company level, Base44 holds SOC 2 Type II and ISO 27001 certification, and the full audit report is available under NDA through its security trust center. For how it stacks up against a wider set of no-code platforms, see our full No-Code App Builders Comparison.
What is Noloco?
Noloco is an operating system for growing service businesses. Instead of generating a new app from a prompt each time, you build inside a single connected system that already has permissions, multi tenant data isolation, workflows, and a noloco.io/solutions/client-portal built in. Several Noloco customers use AI builders like Zite to prototype a specific widget or layout, then embed it inside their Noloco app rather than running their whole business on the prototype itself.
How do credits actually work, and where do they run out?
This is worth its own section, because it’s the part of the pricing model that’s hardest to estimate before you’ve actually used either platform, and it’s the clearest practical difference from how Noloco is priced.
Both Zite and Base44 charge primarily through credits rather than flat fees. On Zite, AI credits and workflow runs are tracked separately, and according to Zite’s own help documentation, exceeding your limit means you can’t publish edits until you upgrade or your monthly limit resets, though already-published apps keep running for your users. One Zite Pro subscriber reported using a full month’s credit allocation in a single day of work in Chat and Plan mode. On Base44, users on the platform’s own official feedback board have reported similar patterns: posts describe minor product changes consuming a significant share of a month’s credits, and the only way to get more credits mid-cycle is upgrading the entire plan, since there’s currently no option to buy a one-time top-up. Credits on both platforms typically don’t roll over to the next billing period.
None of this means either platform is mispriced for what it does. Credit-based pricing makes sense for tools where the AI generation step is the main cost driver. It does mean the monthly bill is harder to predict than a flat per-user fee, especially in a month with heavier iteration. Worth factoring in if your team plans to make frequent changes rather than building once and leaving it alone.
Noloco’s pricing is flat and active-user based rather than credit based, so a busier month of building doesn’t change what you pay. Check the current Noloco pricing page for exact tiers, since pricing changes regularly.
How do Zite, Base44, and Noloco actually compare?
| Feature | Zite | Base44 | Noloco |
| How it builds | AI prompt, then visual editing layer | AI prompt, full-stack code generation | Visual builder on a connected operating system |
| Entry price | ✅ Free, unlimited users | ✅ Free, 25 message credits/month | ✅ Free plan available |
| Pricing predictability | ⚠️ Unlimited users, but credit based with documented cases of a month’s credits used in a day | ⚠️ Credit based, documented cases of fast credit burn, no rollover | ✅ Flat active-user pricing, usage doesn’t change the bill |
| Code export and ownership | ⚠️ Export between Zite accounts only, does not run externally | ✅ Full code export, GitHub on Builder tier+ | ❌ Not applicable, no code generated |
| Company-level security certification | ⚠️ SOC 2 Type II on Enterprise tier only | ✅ SOC 2 Type II and ISO 27001 company-wide | ✅ Built-in audit trails and access controls by default |
| Granular, role-based permissions | ⚠️ Access controls available, expand on Enterprise tier | ⚠️ Basic auth by default, hardening recommended at scale | ✅ Record, field, and view-level permissions on every plan |
| Client portal / external user access | ✅ Marketed directly for this, unlimited users | ⚠️ Possible, less purpose-built for multi-tenant portals | ✅ Built in, multi-tenant data isolation by default |
| Best suited for | Fast builds and client portals, with self-managed review as you scale | Standalone products needing code ownership | Operational systems where permissions are built in from the start |
What’s worth knowing before you scale on either platform?
This is the part most comparison articles skip, and it applies to AI app builders generally, not to either specific tool.
Veracode’s 2025 GenAI Code Security Report tested more than 100 large language models across security-relevant coding tasks and found that 45% of AI-generated code contains a known security vulnerability. That rate held roughly steady across GPT, Claude, and Gemini model generations: bigger, newer models have not meaningfully closed the gap. The report’s own conclusion is direct: current models generate code that works functionally but can miss the security controls a human developer would normally add by default.
That’s a property of how these tools generate code, not a mark against either Zite or Base44 specifically. A platform can be SOC 2 certified at the company level (true of Zite’s Enterprise tier and of Base44 company-wide) while a specific generated app still needs a closer look at rate limiting, session handling, or audit logging before clients log in regularly. Several teams building on Base44, for instance, have raised exactly this with Base44 directly as their apps grew past early usage.
None of this means either tool is unsuitable for real use. It means the honest, slightly less exciting answer is: as usage grows, plan to review what the AI generated, the same way you would with any fast-built software.
Where Noloco takes a different approach is by not generating a new permission system from scratch each time. Every app built on Noloco inherits the same underlying access control, audit trail, and multi-tenant data isolation that the rest of the platform already runs on, so there’s less of that review to do as you scale. If your team is technical and weighing developer-first tools too, our Noloco vs Retool comparison covers that angle directly.
When should you choose Zite, Base44, or Noloco?
Choose Zite when you want to move fast, you’re comfortable iterating through prompts and a visual editor, and you’re fine reviewing permissions and access rules yourself as more people, including clients, start using the app.
Choose Base44 when code ownership matters to you specifically, you want the option to export to GitHub and take the codebase elsewhere, and you’re comfortable planning for some infrastructure hardening as usage and traffic grow.
Choose Noloco when you’d rather that permissions, multi-tenant data isolation, and audit trail work was already built into the foundation, so it’s not something your team reviews and rebuilds as the app scales. See the Noloco Operating System for what that looks like end to end.
| Scenario | Best choice | Why |
| Need a working prototype this afternoon | Zite or Base44 | Both generate a functional app from a prompt in minutes |
| Want to own and export the codebase | Base44 | Full code export and GitHub support on paid tiers |
| Need unlimited internal users without per-seat cost | Zite | Unlimited users included on every plan, including free |
| Want a client portal up fast, comfortable reviewing permissions yourself | Zite | Built directly for this, unlimited users on every plan |
| Clients will log in and you’d rather permissions be built in already | Noloco | Multi-tenant isolation and role-based permissions on every plan, no extra review needed |
| System needs to survive process changes for years | Noloco | Built to evolve without rebuilding from scratch |
| Want to use AI generation for one specific component | Zite or Base44, embedded in Noloco | Use AI for the niche piece, Noloco for the production shell |
Zite and Base44 both do something genuinely useful: get you from idea to a real, working app fast, often with real users on it, without an engineering team. That’s not a small thing, and dismissing either as just a prototyping tool wouldn’t be fair to what they’ve built.
The honest distinction isn’t capability, it’s where the maintenance work sits. With either AI builder, as more people, especially clients, start relying on the app, some of the permissions, scaling, and infrastructure work becomes something your team reviews and manages. With Noloco, that foundation is already part of the platform, so less of it falls on you as the app grows.
If you’ve already built something in Zite or Base44 and you’re now thinking through what it takes to put it in front of clients at scale, that’s a genuinely useful conversation to have early rather than after you’ve hit a limit.
Is Zite or Base44 better for a client-facing portal?
Both can generate login screens, basic access rules, and a working client portal, and Zite in particular markets directly to this use case. The honest caveat is that as more external users log in, it's worth reviewing the generated permissions and access rules yourself rather than assuming they cover every edge case by default, the same way you would with any quickly built software.
Can I export my app from Zite or Base44 if I want to switch later?
Base44 supports code export on Builder tier and above, including export to GitHub. Zite currently allows exporting apps between Zite accounts, but the exported code does not run out of the box in an external environment. Check each platform's current documentation before assuming either path, since export capabilities change as the products evolve.
Does SOC 2 certification mean the app I build is secure?
It's a meaningful signal about how the company manages and protects data internally, but it doesn't automatically certify that every individual app generated on the platform ships with strong authentication, rate limiting, or session handling for your specific use case. Independent research, including Veracode's 2025 GenAI Code Security Report, found that close to half of AI-generated code contains a known security flaw across major model providers. Worth a quick review as your app's usage grows, regardless of which platform generated it.
Is Noloco an AI app builder like Zite or Base44?
No. Noloco is a visual operating system, not a prompt-to-app generator. Some Noloco customers use AI tools like Zite to build small, specific components and embed them inside a Noloco app, using Noloco for the underlying permissions, data, and client-facing structure. If you're coming from Airtable rather than a prompt-based tool, see noloco.io/noloco-vs-airtable for that comparison instead.
What does it cost to run a small internal team on each platform?
Zite includes unlimited users on every plan, including free, so cost scales with usage limits (credits, workflow runs, records, domains) rather than headcount. Base44 charges per workspace tier regardless of user count, with cost driven by message and integration credits. Both platforms have documented cases of credits running out faster than expected, sometimes within a single day of active building, with no rollover and no option to top up without upgrading the whole plan. Noloco uses flat active-user pricing instead, so a heavier month of building doesn't change the bill; check the current Noloco pricing page for exact tiers, since vendor pricing changes regularly.
