Best Tools for Architecture Firms to Track Project Budgets and Timelines in 2026
Struggling with project budgets and timelines? Explore the best tools for architecture firms to plan, track, and deliver projects on time.
Stefania VichiHead of Growth10 min read
Most architecture firms don’t lose money on a project all at once. They lose it slowly — in the hours nobody logged, the scope change nobody invoiced, the consultant coordination that ran long, the CA phase that crept past the fee. By the time the final invoice goes out, the margin is gone. The firm moves on to the next project and loses a little more there, too.
The problem isn’t that architecture firms can’t track budgets and timelines. Most can — quarterly, after the books close. The problem is that quarterly is too late. By then, scope creep has calcified into write-downs, fixed-fee projects have gone underwater, and the client relationship is past the point where renegotiating is easy.
Scoro’s 2025 analysis of architecture firm KPIs found that 78% of budget overruns in a surveyed firm came from inadequately documented change requests (Scoro, 2025). The fix is real-time visibility: fee vs. budget vs. actuals, phase by phase, with alerts before the damage is done. This article covers the 7 tools best suited to deliver that visibility for architecture firms in 2026.
What real-time budget and timeline tracking actually requires
Before comparing tools, define what the tracking job actually is. A tool that claims to “track project budgets” but doesn’t distinguish between fee, budget, and actuals is solving a different problem.
Three numbers, always visible
Architecture projects run on three financial numbers that must be separately tracked and compared:
  • Fee: what’s contracted. Fixed amount, percentage of construction cost, hourly not-to-exceed, or a hybrid. This is what the client agreed to pay.
  • Budget: what you planned to spend delivering it. Hours by role × billing rate, plus expenses, plus consultant costs. This is your internal cost plan.
  • Actuals: what you’ve actually spent so far. Hours logged, expenses incurred, consultant invoices received.
The gap between fee and budget is your planned margin. The gap between budget and actuals is your variance. When actuals approach budget before the phase is complete, you have a problem. When actuals exceed fee, you have a crisis.
Phase-level, not project-level
A project that’s “75% budget spent” could be fine (if it’s 80% complete) or in serious trouble (if it’s 40% complete). Project-level totals hide the real signal. Tracking at the phase level — Schematic Design, Design Development, Construction Documents, Construction Administration — surfaces the problem before it becomes systemic.
Percent complete, not percent elapsed
Time elapsed is not progress. A CD phase that’s used 90% of its time budget could be 90% complete or 50% complete. The tool needs to track percent complete against the deliverables, not against the calendar.
Alerts before the damage
A good tool flags problems at 30%, 60%, and 80% budget consumed — so someone can look at it before the overrun is unfixable. A tool that reports overruns after the fact is a reporting tool, not a tracking tool.
Why most tracking approaches fall short
The tracking gap is usually not a tool gap — it’s a process gap that tools amplify or mask.
Time tracking in one system, budgets in another
The most common setup: hours tracked in Harvest or Toggl, budgets maintained in a spreadsheet, fees stored in Google Drive, consultant costs tracked in QuickBooks. Reconciliation happens monthly, if at all. By the time the picture is complete, the intervention window is closed.
Hours logged late
A timesheet filed on Friday for the whole week is already too late for intervention on Monday. Real-time visibility requires real-time inputs — ideally daily or same-day time capture, which requires a tool the team will actually use every day.
No phase structure in the tool
Generic time tracking tools treat “Project X” as one bucket. But Project X probably has four to six phases with different budgets and timelines. Without phase structure in the tool, the signal you need (which phase is over-budget) is invisible.
# Tool Best for
1 Monograph AEC-native real-time fee tracking for firms 5–30 people
2 Deltek Ajera Comprehensive AEC financial tracking at SMB scale
3 BQE Core Firms prioritizing time and billing depth
4 Noloco Firms wanting their own fee structures and phase definitions tracked in real time
5 Harvest + Forecast Lightweight time and resource planning (with manual fee tracking)
6 Toggl + Spreadsheets Very small firms with simple projects
7 Bonsai Solo practitioners or 2–3 person firms
The 7 best tools for tracking budgets and timelines: detailed reviews
1. Monograph
Monograph’s real-time fee tracking is the feature it’s most known for in AEC circles. Projects are structured around phases with contracted fees and budgets, and the dashboard shows burn against fee continuously. It’s the tool most firms benchmark against when evaluating this specific job.
How it handles the three numbers: Fee is set at contract. Budget is planned by phase. Actuals update as hours are logged. The visual dashboard shows all three side by side with health indicators.
Strengths: purpose-built for this job, AEC-native phases, fast implementation, clean UX that team members actually use.
Limits: works best if your fee structure matches Monograph’s template (hourly, fixed-fee, percentage-of-construction); hybrid or unusual fee models require workarounds; client portal is basic.
Best for: architecture firms 5–30 people whose delivery fits standard AEC patterns.
2. Deltek Ajera
Deltek’s SMB product for AEC firms. More comprehensive than Monograph on financial depth but also heavier to implement. Fee tracking is robust, with support for complex billing arrangements, multi-phase projects, and consultant cost integration.
How it handles the three numbers: All three tracked natively, with WIP reporting, revenue recognition logic, and phase-level P&L.
Strengths: Deltek’s AEC data model at SMB pricing, strong on financial compliance, integrated accounting.
Limits: inherits Deltek’s legacy UX, 1–3 month implementation, customization is limited, cost climbs as modules are added.
Best for: AEC firms 10–40 people where financial depth and reporting sophistication matter more than UX.
3. BQE Core
BQE Core leads with time and billing. Fee tracking is solid, budget management is strong, and the reporting layer is one of the best in the SMB AEC category. PM features are present but feel secondary.
How it handles the three numbers: Fee tracked at project/phase; budget defined in hours and dollars; actuals update from timesheets in real time.
Strengths: strong reporting, good time/billing depth, integrates well with QuickBooks and Xero.
Limits: dense interface, PM felt less AEC-native than Monograph, customization limited.
Best for: AEC firms where the finance lead is the primary decision-maker on tooling.
4. Noloco
Noloco takes a configurable approach. Instead of a predefined fee-tracking model, the firm defines its own fee structures, phase definitions, budget logic, and variance alerts — without code. This fits firms whose fee models don’t match standard templates (hybrid fees, custom phase structures, sub-consultant coordination).
How it handles the three numbers: You configure the data model to match your fee structure. Time entries link to projects and phases. A live dashboard shows fee, budget, and actuals with the logic you defined — percent complete calculations, variance thresholds, and health indicators.
Strengths: configurable to your exact fee logic and phase structure, branded client portal for sharing fee and timeline transparency with clients, workflow automations for variance alerts, bundle-seat pricing that doesn’t penalize adding project team members.
Limits: requires upfront configuration — you’re defining the tracking logic, not adopting a template; not the right tool for firms that want turnkey AEC pre-builds.
Best for: growing AEC firms 10–50 people with custom fee structures or phase definitions that don’t cleanly fit opinionated tools.
5. Harvest + Forecast
The lightweight standard. Harvest handles time tracking and invoicing; Forecast handles resource planning. Used together, they give you actuals (Harvest) and planned hours (Forecast) — but fee tracking lives in a spreadsheet alongside.
How it handles the three numbers: Actuals tracked in Harvest with project budgets (hours or dollars). Fee tracked manually elsewhere. Comparison requires export or integration.
Strengths: clean UX, strong adoption, inexpensive, solid invoicing.
Limits: not AEC-native, no phase structure, no real-time three-number view, fee tracking always happens outside the tool.
Best for: very small firms (2–8 people) running simple hourly projects, willing to maintain a fee spreadsheet alongside.
6. Toggl + Spreadsheets
The honest default for many small firms. Toggl captures time; a spreadsheet captures everything else. This works up to a point — usually 5–8 people — then breaks when nobody can tell which project is actually profitable.
How it handles the three numbers: Actuals in Toggl. Fee and budget in a spreadsheet. Manual reconciliation — and that reconciliation is the weakest link.
Strengths: cheap, flexible, zero learning curve for the spreadsheet part.
Limits: doesn’t scale, reconciliation gap widens with every project, no alerts, no phase structure.
Best for: 2–5 person firms with simple projects — and only until the firm outgrows the pattern.
7. Bonsai
Bonsai is built for freelancers and very small service firms. It covers time tracking, contracts, and invoicing in one tool. Not AEC-specific, but some solo architects and 2–3 person firms use it effectively.
How it handles the three numbers: Project-level budgets and fees; actuals from time tracking. No phase structure.
Strengths: integrated contracts, invoicing, and time tracking in one tool; low friction for solo practitioners.
Limits: not AEC-native, no phase tracking, no consultant coordination, caps out around 3–5 people.
Best for: solo architects and 2–3 person firms with simple project structures.
Comparison: how each tool handles budget and timeline tracking
Capability Monograph Ajera BQE Core Noloco Harvest + Forecast Toggl + Sheets
Fee vs. budget vs. actuals in one view ✅ Yes ✅ Yes ✅ Yes ✅ Configurable ❌ No ❌ No
Phase-level structure ✅ Yes ✅ Yes ✅ Yes ✅ Configurable ⚠️ Limited ⚠️ Limited
Real-time burn rate ✅ Yes ✅ Yes ✅ Yes ✅ Yes ⚠️ Partial ❌ No
Variance alerts ✅ Yes ✅ Yes ✅ Yes ✅ Configurable ⚠️ Basic ❌ No
Consultant cost integration ⚠️ Moderate ✅ Deep ⚠️ Moderate ✅ Configurable ⚠️ Limited ⚠️ Manual
Client visibility ⚠️ Basic ⚠️ Limited ⚠️ Basic ✅ Branded ❌ No ❌ No
Implementation time Weeks 1–3 mo 1–3 mo Weeks Days Days
How to roll this out across the firm
The best tool is useless if the team doesn’t keep the data current. A real-time tracking capability only produces real-time insight if timesheets, expenses, and percent-complete updates land within a few days of the work happening. Getting there is a rollout question, not a software question.
Week 1: Get everyone tracking time consistently
Before anything else, the team needs a single shared way to track hours — daily ideally, Friday-latest as a backstop. Enforce project and phase coding. Accept that the first week will be messy; measure the second week.
Week 2–3: Set up fee proposals and budget baselines
Load contracted fees and phase-level budgets for all active projects. This is the baseline against which everything else compares. Don’t skip phase-level — a project-level budget is the most common reason firms can’t diagnose overruns.
Week 4+: Weekly project profitability review
A 30-minute weekly review where principals and project managers look at fee, budget, and actuals across all active projects. Flag variances. Decide on interventions. This ritual matters more than any tool feature.
Who owns it
The accountability typically sits with the studio manager or operations lead — the person who reviews the data and triggers interventions. If nobody owns this, the tool becomes a reporting system rather than a management system. That distinction is the difference between visibility and impact.
Warning signs your tracking approach is broken
  • You discover a project was unprofitable after it closed, not during delivery
  • Timesheets are regularly filed 1–2 weeks late
  • Budget conversations happen quarterly, not weekly
  • Principals maintain “shadow spreadsheets” because the tool doesn’t match how they think about the project
  • Change requests get absorbed into the original fee without a formal documented amendment
  • Consultant invoices arrive after the project is closed
  • Nobody can answer “which of our active projects is least profitable right now?” in under 2 minutes
Any three of these together indicate the tracking infrastructure is reactive rather than preventive. The software change alone won’t fix it — but software that makes the weekly review easier is a necessary component.
The best tool for tracking budgets and timelines is the one your team will actually use every week, connected to the fee and phase structure your firm actually delivers. Tools that produce perfect reports once a month are less useful than tools that produce imperfect reports every week — because the intervention window is the point.
For most growing AEC firms, the practical shortlist is Monograph (if your fee structure fits the template), Noloco (if you want to configure the tracking to your own model), or Ajera (if financial depth matters most). Harvest + Forecast and Toggl + spreadsheets are genuine starting points for very small firms, but both hit their ceiling around 5–8 people.
The rhythm matters as much as the tool. Weekly profitability reviews, time tracked same-day, change requests documented before they’re worked, and fee variances escalated at 60% budget consumed — these practices create the visibility; the tool just makes them sustainable.
What is the best way for architecture firms to track project budgets in real time?
Real-time tracking requires three things: a tool that shows fee, budget, and actuals in one view at the phase level; daily or same-day time capture by the team; and a weekly review rhythm where variances are flagged and acted on. For firms with standard AEC fee structures, Monograph delivers this out of the box. For firms with custom fee structures, a configurable platform like Noloco provides the same visibility tailored to your exact model.
How do I stop scope creep from eroding my project margins?
Scope creep is a systemic issue, not a behavioral one. The Scoro study cited in this article found that 78% of overruns in a surveyed firm came from inadequately documented change requests. The fix has two parts: a formal change request process (scope change must be logged, estimated, and approved before work begins) and a tool that tracks budget consumption in real time so scope creep is visible within days, not months.
Can I track project budgets in spreadsheets?
For very small firms (2–5 people) with simple projects, yes. Beyond that, spreadsheets break down — not because they lack features, but because they lack live data. Time entered in a different system, fees in Google Drive, and consultant invoices in QuickBooks create a reconciliation gap that widens every week. The symptom is always the same: you find out about overruns a month after they happened.
How often should I review project profitability?
Weekly for active projects. Monthly is too slow for intervention — by month-end, a fixed-fee project with a 4-month timeline has already consumed 25% of its budget without any visibility. A 30-minute weekly review focused on fee vs. budget vs. actuals across all active projects is the industry norm for firms that maintain healthy margins.
Does Noloco integrate with QuickBooks or Xero?
Noloco integrates with QuickBooks, Xero, and other accounting systems through direct integrations or via Zapier, Make, and n8n. This lets the firm keep accounting in its existing tool while the operational tracking (fee, budget, actuals, phases, client portal) lives in Noloco. Consultant invoices logged in QuickBooks can flow back into the project view, giving a complete picture of project profitability.
What's the minimum firm size for investing in dedicated budget tracking software?
Around 5–8 people is the typical inflection point. Below that, a disciplined spreadsheet plus Toggl can work — if the principal keeps both current. Above that, the reconciliation gap between tools becomes too wide to maintain manually, and the cost of a missed overrun exceeds the cost of dedicated software. Firms that wait past 10 people usually report regretting the delay.
