Best Project Management Tool for an Agency (2026 Guide)
Most project management tools weren't built for agencies. This guide compares the top options for 2026 — and explains why more agencies are switching to an Agency OS instead.
Stefania VichiHead of Growth7 min read
Why Agencies Need More Than a Generic Project Management Tool
There’s a common mistake agencies make when they’re growing: they buy the most popular project management tool on the market and expect it to solve their delivery problems.
It doesn’t.
That’s not a criticism of those tools — it’s a category mismatch. Tools like Asana, Monday, or ClickUp were designed for internal teams tracking tasks. Agencies operate differently. You’re managing projects for multiple clients simultaneously, each with different workflows, different stakeholders, and different expectations around transparency.
The result? Most agencies end up with what we call tool sprawl: a project management tool for tasks, a separate CRM for client relationships, another tool for time tracking, a client portal bolted on as an afterthought, and Slack holding everything together with duct tape. Nothing talks to anything else. Your team wastes hours manually updating statuses across systems. Clients email asking for updates that live three tools away.
Here’s what agencies actually need from project management software:
  • Multi-client visibility — see all active projects across all clients in one view
  • Client-facing transparency — give clients real-time access without granting full system access
  • Custom workflows — different clients and service lines need different processes
  • Integrated operations — CRM, project tracking, time logging, and client communication in one place
  • Scalable permissions — control exactly what each client, contractor, and team member sees
Most tools check two or three of those boxes. Very few check all five.
The Top Project Management Tools for Agencies (2026)
1. Noloco — Best for Agencies Who Want to Build Their Own System
Noloco isn’t a traditional project management tool. It’s a no-code platform that lets agencies build exactly the system they need — without writing a line of code. Think of it as the operational layer of your agency: project tracking, client portal, CRM, reporting, and automations all living in one connected platform.
What makes it different:
Unlike off-the-shelf tools, Noloco lets you define your own data structure, workflows, and client-facing views. If your agency tracks campaigns differently from websites, or handles retainers differently from project-based work, you can build that distinction directly into the platform.
With Noloco’s project management solution for agencies, you can:
  • Build a fully branded client portal where clients can check project status, access deliverables, and leave feedback — without emailing your team
  • Automate repetitive workflows like onboarding checklists, approval requests, and status updates
  • Connect to your existing tools (Airtable, Google Sheets, HubSpot, and more) via native integrations
  • Set granular permissions so each client only sees their own data
  • Create custom dashboards that surface the metrics that matter to your business
Best for: Agencies ready to move off spreadsheets and disconnected tools, and build one unified system for client delivery.
Pricing: Starts at competitive no-code platform rates. See noloco.io/pricing for current plans.
2. Monday.com — Best for Visualizing Complex Projects
Monday.com has built a strong reputation as one of the most visually intuitive project management platforms available. Its drag-and-drop boards, multiple view options (Gantt, Kanban, timeline), and automation library make it genuinely useful for creative agencies managing multi-stage production workflows.
Strengths:
  • Highly visual interface that non-technical team members pick up quickly
  • Strong automation capabilities for repetitive task sequences
  • Good integration library with tools like Slack, Google Drive, and Zapier
Where it falls short for agencies:
  • Client-facing features require extra configuration and often look like the Monday.com product, not yours
  • Pricing scales steeply with team size
  • Limited ability to customize data models to match your unique service delivery structure
Best for: Mid-size creative or marketing agencies with primarily internal project tracking needs.
3. Asana — Best for Structured Task Management
Asana is one of the most widely adopted project management tools globally, and for good reason. Its task hierarchy, project templates, and goal-tracking features make it a solid choice for agencies with clear, repeatable delivery processes.
Strengths:
  • Intuitive task management with subtasks, dependencies, and milestones
  • Strong project template library speeds up new project setup
  • Reliable mobile experience
  • The client-facing experience is limited without third-party workarounds
  • Reporting features require the Business tier, which significantly increases cost
  • Not designed for multi-client data management — keeping client data separate requires manual discipline
Best for: Smaller agencies or individual project managers who need structured task tracking for internal teams.
4. ClickUp — Best for Customization Without No-Code
ClickUp markets itself as the “everything app” for productivity, and it genuinely offers a lot of flexibility. Custom fields, multiple views, built-in docs, and time tracking make it one of the more feature-rich tools in the category.
Strengths:
  • High customization potential within a single platform
  • Strong free tier makes it accessible for small agencies
  • Built-in time tracking reduces the need for a separate tool
  • The volume of features creates a steep learning curve; many teams use 20% of the tool
  • Client portal functionality is limited — clients get system access, not a tailored experience
  • Performance can slow with large workspaces
Best for: Tech-forward agencies who want to configure a single tool rather than buy a dedicated platform.
5. Teamwork — Built for Agencies, But Showing Its Age
Teamwork is one of the few project management tools purpose-built for agencies, with features like profitability tracking, client billing, and retainer management included out of the box.
Strengths:
  • Retainer management and billing features tailored to agency service models
  • Client portal with some customization options
  • Time tracking and invoicing built in
Where it falls short:
  • The interface feels dated compared to newer entrants
  • Less flexibility for agencies with non-standard delivery models
  • Integration options are more limited than competitors
Best for: Established agencies with traditional retainer-based billing who prioritize time-and-billing features.
What to Look for When Choosing Agency Project Management Software
Before you commit to any platform, run it through this checklist:
1. Can clients access their project status without emailing you? If the answer is no, you’re going to keep fielding status update requests. Look for tools with a proper client-facing layer — not a shared login to your internal workspace.
2. Can you customize workflows per client or service type? A branding agency runs differently from a development shop. Your project management system should reflect that, not force you into a generic template.
3. Does it connect to the tools you already use? The best platforms integrate with your existing stack — whether that’s Airtable, HubSpot, Google Sheets, or your accounting software — rather than replacing everything at once.
4. Does pricing scale reasonably as you grow? Per-seat pricing models can become expensive fast. Understand the cost at 10 people, 25 people, and 50 people before you commit.
5. Can you see all clients in one view, not just one project at a time? Agency managers need a bird’s-eye view across all active work. If you’re clicking into individual projects to understand capacity, you’re spending time you don’t have.
Why More Agencies Are Moving to an Agency OS Instead
The category of project management software is evolving. The agencies we talk to aren’t just looking for a task tracker — they’re looking for a unified operational layer that connects project delivery to client management to team visibility.
That’s the thinking behind the Agency Operating System model. Rather than bolting together a project management tool, a CRM, a client portal, and a reporting dashboard — each with its own login, its own data model, and its own subscription — agencies are increasingly building a single connected system on top of a flexible no-code platform.
With Noloco as your Agency OS:
  • Projects, clients, and team tasks live in one connected data model
  • Clients get a branded portal experience that reflects your agency’s identity
  • Automations handle the repetitive work (onboarding emails, status updates, approval requests)
  • You build to your process, not someone else’s template
  • New team members onboard faster because the system matches how you actually work
The result is less time managing tools and more time doing the work clients pay for.
The Cost of Getting This Wrong
Most agencies underestimate the cost of running on the wrong project management tool. It’s not just the subscription fee — it’s the compounded overhead:
  • Hours spent copy-pasting updates between systems
  • Client churn from poor communication and transparency
  • Senior team members fielding avoidable status questions
  • Onboarding delays every time a new client starts
  • Errors when data lives in multiple disconnected places
The hidden cost is almost always higher than the visible one. The right system pays for itself in recovered hours alone.
How to Get Started
If you’re evaluating project management tools for your agency, the fastest way to find the right fit is to map your actual workflow first:
  • List every step in your current project delivery process
  • Identify where work gets stuck, duplicated, or manually transferred
  • Map which client touchpoints currently require your team to intervene
  • Evaluate tools based on how well they address those specific gaps
If you find that your gaps span multiple categories — project visibility, client communication, operations — it’s worth exploring whether a purpose-built Agency OS fits better than a standalone project management tool.
→ Explore Noloco’s Agency OS
→ See the project management solution for agencies
→ Start for free
What is the best project management tool for a small agency?
For small agencies (under 10 people), Asana or ClickUp offer accessible starting points. But if client communication and transparency are priorities from day one, Noloco’s no-code platform scales more effectively as you grow.
Do agencies need a special project management tool?
Not necessarily a “special” tool — but they need one that handles multi-client visibility, client-facing access, and custom workflows. Most general-purpose tools weren’t designed with those use cases as priorities.
What’s the difference between a project management tool and an Agency OS?
A project management tool tracks tasks and timelines. An Agency OS connects project delivery to client management, operations, and reporting in one unified system — reducing tool sprawl and giving your whole team a single source of truth.
Can you use Noloco as a project management tool?
Yes. Noloco’s no-code platform lets agencies build fully custom project management systems — including Kanban boards, Gantt views, client portals, automated workflows, and multi-client dashboards — without writing code.
How much does agency project management software cost?
Pricing varies significantly. Asana and ClickUp offer free tiers with limitations. Monday.com starts around $10–12/seat/month. Noloco’s pricing is structured by plan rather than per seat, which can represent significant savings at team scale. See noloco.io/pricing for current plans.
