Zoho alternatives: buy another CRM or build your own?
Comparing Zoho alternatives? See how Airtable, Softr, monday.com, Glide, and Quickbase stack up against building a custom no-code CRM instead.
Boglarka HeraGrowth Manager8 min read
You didn’t outgrow Zoho because it’s a bad tool. You outgrew it because your firm’s process doesn’t fit neatly into anyone’s template, and every workaround you’ve bolted on since setup has made the system a little harder to trust.
So you start looking at Zoho alternatives. The problem is that most “alternatives” lists only offer you a different flavor of the same thing: another pre-built CRM with its own templates, its own pricing tiers, and its own version of the exact ceiling you just hit.
There’s a second option that rarely gets framed clearly: instead of buying another closed CRM, you build the one your firm actually needs on top of a no-code platform. This guide walks through both paths so you can tell which one actually solves your problem.
Why are service businesses looking for Zoho alternatives?
Zoho CRM is priced reasonably at the entry level, and for a small team with a simple pipeline, it does the job. The friction shows up as firms grow: custom fields, advanced workflow automation, and multi-user portals live behind the Enterprise and Ultimate tiers, and pricing runs per user from roughly $14 to $52 a month depending on plan.
That’s a familiar shape. It’s not that Zoho is uniquely restrictive, it’s that any CRM built to serve thousands of different businesses has to draw its customization lines somewhere, and those lines rarely land exactly where your firm needs them.
By 2025, 70% of new business applications used low-code or no-code technology, up from less than 25% in 2020, according to Gartner (2021). A meaningful share of that shift is CRM, because customer data is exactly the kind of thing every firm structures a little differently.
What’s the real choice: another CRM, or a system you build yourself?
Most “Zoho alternatives” content compares you to other closed CRMs: Pipedrive, HubSpot, Salesforce. Those are worth knowing about, but they solve a narrower problem than the one most operations leads are actually facing.
If your complaint is “Zoho is too expensive for what we use,” another CRM might fix that. If your complaint is “our process doesn’t fit any CRM’s default fields and stages,” switching to a different closed tool usually just delays the same conversation by twelve months.
No-code platforms answer a different question: instead of picking the CRM whose template happens to fit best, you define the fields, the stages, the permissions, and the automations yourself, on top of your own data. 71% of small businesses already use some form of CRM system, according to a 2024 Freshworks survey of 600 US business owners, which means most of this audience isn’t choosing whether to use a CRM. They’re choosing whether to keep renting someone else’s structure or build their own.
Here’s how Zoho stacks up against the field, including the no-code route.
Dimension Zoho CRM Airtable Softr monday.com Glide Quickbase Noloco
Pricing model Per user, $14 to $52/mo depending on tier Per seat, plus per-editor Interface pricing Per seat Per seat, guest pricing for external users Per user, usage-based tiers Per seat, enterprise pricing Flat active-user pricing, no per-seat client fees
Customization without code ⚠️ Gated by tier, deep customization needs Enterprise+ ✅ Strong on data structure ⚠️ Limited to pre-built blocks ⚠️ Board and template based ⚠️ Basic, limited backend logic ✅ Deep, but needs technical setup ✅ Full data model and workflow control
Client-facing permissions ⚠️ Multi-user portals from Enterprise tier up ❌ Not built for client logins ⚠️ Page-level only ❌ Role-based only, paid guest seats ❌ Not built for client logins ✅ Yes, role-based ✅ Field and record-level permissions
Where your data lives Zoho’s own database Native spreadsheet-style database Connects to Airtable or Supabase Native database Connects to Airtable or Google Sheets Native, plus integrations Airtable, Noloco Tables, PostgreSQL, MySQL
Best fit Simple pipeline, budget-conscious, no client access needed Teams that want structured data before adding a front end Quick client dashboards on existing Airtable data Familiar internal sales tracking Mobile-first field data, not full CRM IT-led enterprise deployments CRM, delivery, and client portal in one connected system
When does building your own CRM make more sense than buying another one?
Buying another CRM makes sense when your process is genuinely standard: a simple sales pipeline, a handful of stages, no client-facing access required. In that case, the fastest fix is often just picking a cheaper or simpler off-the-shelf tool.
Building makes more sense once any of these are true:
  • Your pipeline needs to connect to delivery, invoicing, or a client portal, not just sit as a standalone sales tool.
  • Clients or external partners need to log in and see only their own records, not a shared view with everyone else’s data.
  • You’ve already tried two CRMs and hit the same customization ceiling both times.
  • Your team is spending real time each week working around the tool instead of in it.
That last point matters more than it sounds. A rigid CRM doesn’t just annoy your team, it quietly trains them to keep a shadow spreadsheet next to it “just in case,” which defeats the point of having a system of record at all.
Stay on Zoho (or switch to another closed CRM) if Consider a no-code build instead if
Your pipeline is simple: a handful of stages, no client access required Clients or partners need their own login showing only their records
Your main complaint is price or interface, not structural fit Your CRM needs to connect directly to delivery, invoicing, or project tracking
Your team hasn’t hit a customization ceiling yet You’ve already switched CRMs once and hit the same wall again
You want a system live in days with minimal setup Your team keeps a shadow spreadsheet next to the CRM to work around it
You have no existing structured data to build from You’re already on Airtable or Sheets and don’t want to lose that data
How do Airtable, Softr, monday.com, and Glide compare as Zoho alternatives?
Airtable
Airtable is the most common starting point for firms building their own CRM, and for good reason: linked records, custom fields, and views make it a genuinely flexible database. Many operations leads are already keeping some part of their business in an Airtable base.
Where it stops being enough as a CRM on its own is client access. Airtable’s sharing options are built for internal collaboration, not for giving a client a login that shows only their records. Firms that like their Airtable data usually keep it as the source of truth and add an interface layer on top rather than migrating away from it.
Softr
Softr turns an Airtable or Google Sheets base into a client-facing site or portal fast, which makes it a reasonable next step once Airtable alone isn’t enough for client visibility. Pre-built blocks get a simple deal tracker with a client login running quickly.
The tradeoff shows up as your process gets more complex. Permissions are managed page by page rather than at the data level, which gets harder to keep secure as your client list grows, and Softr pulls data live from the source on every page load, which can slow things down at scale.
monday.com
monday.com’s CRM template is familiar and easy to sell internally, since most teams have already used its boards for project tracking. It handles an internal-only sales pipeline well.
It wasn’t built around external, client-facing use. Giving clients access typically means per-seat guest pricing, and permissions are role-based rather than field-level, so there’s no clean way to let a client see some records but not others within the same view.
Glide
Glide is strong for fast, mobile-friendly apps on top of a spreadsheet or Airtable base, particularly for field teams who need a lightweight view on a phone.
As a full CRM, it’s a harder fit. Backend logic is limited, so multi-step workflows and more complex relational data tend to break down. It’s a better match for simple record-and-view use cases than for a CRM tied into delivery and billing.
Quickbase
Quickbase sits at the enterprise end of this comparison: relational data, role-based permissions, and serious workflow automation, built for organizations with a dedicated IT function.
For a 10 to 50 person service business without an in-house developer, that depth comes at a real cost. Implementation usually needs a consultant or technical lead, pricing is enterprise-tier, and the learning curve for non-technical operators is steep. It earns a place in this comparison because it comes up in searches, but it’s rarely the right fit for this size of firm.
Noloco takes a different position in this comparison: instead of a CRM template you customize within someone else’s limits, it’s an operating system for service businesses where your CRM, delivery tracking, and client portal all run on the same connected data.
You can connect Noloco directly to an existing Airtable base, so nothing has to be re-entered, or build your data model from scratch inside Noloco. On top of that, field-level and record-level permissions mean your team and your clients can share the same system while seeing only what’s relevant to them, and pricing is based on active users rather than per seat, so client access doesn’t carry the same cost penalty it does with Zoho’s guest-style pricing or per-seat competitors.
That combination is what makes it worth considering alongside the “buy another CRM” option: instead of trading one set of limits for another, you’re removing the ceiling entirely.
How should you actually decide?
Start by naming the specific thing that’s broken. “Zoho feels expensive” and “Zoho can’t model our delivery process” are different problems with different fixes, and it’s worth being honest about which one you actually have before you evaluate anything.
If it’s genuinely a pricing or interface complaint and your process is simple, a cheaper off-the-shelf CRM may be the fastest fix. If it’s a structural fit problem, no closed CRM, Zoho or otherwise, will solve it permanently. That’s the signal to look at a no-code build instead.
From there, match the tool to what’s actually missing: Airtable if you need a better database and nothing else yet, Softr or monday.com if you need a simple client-facing layer on top of what you already have, and a connected system like Noloco if the CRM, delivery, and client access all need to work together without three separate subscriptions and a pile of Zapier automations holding them together.
There’s no universally right answer between buying another CRM and building your own. Both are legitimate paths, and the honest version of this decision depends entirely on how far off-template your actual process runs.
What’s worth avoiding is spending another year hopping between closed CRMs that each solve one complaint and introduce a new one. If you’ve already done that once, the pattern is unlikely to change the second time. Building on a flexible foundation, whether that’s your existing Airtable data or a fresh system, tends to be the version of this decision that firms don’t have to revisit again in twelve months.
What's the main difference between a Zoho alternative and a no-code CRM?
A Zoho alternative like Pipedrive or HubSpot is still a closed CRM with its own template and its own limits. A no-code CRM lets you define the fields, stages, permissions, and automations yourself, so the system follows your process instead of the other way around.
Is it cheaper to switch CRMs or build one?
It depends on your team size and process complexity. Switching CRMs usually has a lower upfront cost but risks hitting the same customization ceiling again. Building takes more setup time initially but tends to cost less over time once client access and automation needs grow.
Can I keep my Zoho data if I move to a no-code platform?
Yes, most no-code platforms support CSV import or direct integrations, and you're not required to migrate everything at once. Many firms start by exporting core records (contacts, deals) and rebuild workflows from there rather than a full one-time cutover.
Do I need a developer to build my own CRM in a no-code tool?
No. Platforms like Airtable, Softr, monday.com, and Noloco are built for non-technical teams using visual builders. Quickbase is the exception in this comparison; it's low-code and typically needs technical implementation support.
Is Airtable a CRM on its own?
Airtable can function as a basic CRM for internal pipeline tracking, but it lacks native client-facing permissions and portals. Most firms that build a CRM on Airtable add a front-end layer like Softr or Noloco on top to handle client access.
What should I check before switching off Zoho?
Map the specific limitation you've hit (pricing, customization, client access, automation) before comparing tools. This tells you whether another closed CRM will actually fix the problem, or whether you need a platform flexible enough to be shaped around your process instead.
Boglarka Hera
Growth Manager at Noloco
